<  Hobby Section  ~  FYI: Bachman/Lionel on sale
PostPosted: Fri Sep 25, 2009 2:19 pm
For those that like the O scale terrain buildings/elements. . .
trainhobbies.com is having a $10 off sale. When checking out, use code 011B1 and get $10 off of a $50 order.
I have purchased both Bachman Plasticville and Lionel ranges in the past. The Bachman stuff is prety nice and the "kit" is the way to go. A layer of primer, a coat or 2 of paint and you're done. The lionel stuff is already painted in the form of multicolored plastic. It looks okay, but you can get some good results with minimal work on the Bachman stuff.
Bachman also has a few multi-story buildings like their apartment complex.
I don't have a LGS or Local Train Shop that sells these, so I use the internet. Obviously if you have a local shop that sells these you should support them.
PostPosted: Fri Sep 25, 2009 2:59 pm
Thanks for the heads up!
