<  Hobby Section  ~  Kunzomats building blog
PostPosted: Wed Nov 17, 2010 10:35 am
User avatarMortalPosts: 27Joined: Wed Jul 01, 2009 3:46 pm
I can not only use a brush. Some times i also use a knife an build some things. Here are the Results.
Edit: better?
PostPosted: Wed Nov 17, 2010 11:59 am
That pier looks to be a very promising start; will we see more pics as you go along? (I hope so.)
Very nicely done. :)
PostPosted: Fri Dec 03, 2010 9:51 am
So i start the work on the second Part of the Table...
PostPosted: Mon Dec 06, 2010 2:01 am
Looking good!
PostPosted: Wed Jan 05, 2011 9:04 am
So here are the next step
PostPosted: Wed Jan 05, 2011 10:15 am
Looking very good. :)
What is the grey-green maaterial you are using with the cork?
PostPosted: Fri Jan 28, 2011 9:27 am
So here ist the next step...
@leonmallett: the green material are 3mm foam panels called Depron/Selitron. This stuff where use for insulation.
PostPosted: Sat Jan 29, 2011 10:39 am
Lokks like it will be a great looking piece. :)
PostPosted: Wed Mar 16, 2011 1:02 pm
User avatarMortalPosts: 18Joined: Mon Apr 06, 2009 6:58 am
Very nice.
can you tell me the thickness of the cork?
Users browsing this forum: Google [Bot] and 1 guest
