<  Law & Order in Pulp City  ~  Recovering from Incapacitation and 'states'?
PostPosted: Sat Dec 31, 2011 12:56 am
When a supreme is incapacitated and then is subsequently revived, do they keep any continuous effects/states/counters/anything they had from before they became incapacitated? For instance,
- Ace of Wraiths becomes Spectral which lasts until his next activation but then gets blown up, does he get revived still spectral?
- Doc Mercury's Anvil/Spike Hand?
- Anyone's Aura power?
- Do models keep any character specific "points" such as Silver Rager's or Taurus' Rage points or Tangents Tangent points, or do they reset to zero?
So many interacting rules! :)
PostPosted: Sat Dec 31, 2011 1:50 am
I don't think any states remain...but I'm not the rules guy Leon or Devon is nor the developer like Devon.
Incapacitated essentially is dead, so every thing on the model should be removed.
PostPosted: Sat Dec 31, 2011 9:13 am
If from Ace of Wraiths I would say no, since neither Skills nor Actions can be used while Incapacitated; 'use' may be interpreted as launching the Action, but arguably any ongoing application should count as 'use' since 'use' is not a defined game term, it does then require interpretation. However if they cannot be 'used' then the lasting benefit does not apply.
Cease as these are Actions (can't use Actions while Incapacitated, as above).
Cease as Auras are Actions (can't use Actions as above).
Unless specifically stated otherwise, these will remain as the Guide does not list them as removed. It seems slightly counter-intuitive, but follow the Incapacitated text and you should be fine. :)
Indeed. :)
