<  Law & Order in Pulp City  ~  LOS and Cover in the rulebook??
PostPosted: Tue Mar 06, 2012 1:14 pm
User avatarMortalPosts: 18Joined: Mon Apr 06, 2009 6:58 am
He guy's,
Been reading the rulebook and I'm confussed and I know you guy's can help me out :wink:
In the rulebook on page 18 it says that a model must be obstructed 50% by cover to get the "In cover" penalty.
The picture above the rule shows Androida beeing blocked for like 5% by the car and its says "LOS + In cover"
I'm I reading the rule wrong????
PostPosted: Tue Mar 06, 2012 2:55 pm
Method wrote:
He guy's,
The rules are correct. The picture is just slightly off as Androida leans forward over the base. Not that the rules for LoS mention bases, but in the picture, 50% of Androida's base is covered. Not the best illustration to get the idea for LoS.
So, to gain cover, 50% of a model, not including raised weapons, capes, etc, has to be blocked from LoS.
Hope that helps.
PostPosted: Tue Mar 06, 2012 4:56 pm
MortalPosts: 5Joined: Sun Mar 04, 2012 8:23 pm
Is LOS measured from ground level (the center point of a model's base) or from eye level (so bigger models, or models with more elaborate raised bases can see better than others)?
oMAD >> http://dogui.wordpress.com/
PostPosted: Tue Mar 06, 2012 5:41 pm
From the middle of the attacking model's base to target model. So it's base level to target model (barring capes, weapons, etc).
PostPosted: Tue Mar 06, 2012 8:12 pm
Gracias!
