<  Law & Order in Pulp City  ~  Question about Rays
PostPosted: Sun Apr 08, 2012 5:24 pm
User avatarMortalPosts: 4Joined: Sun Apr 08, 2012 5:01 pm
When reading about a Ray range attack it seems clear for me that the Ray would affect all the models that are in the Ray Template. However when I read the description of the Father Oak Ray it says that it affects all the models in the Template, being an exceotion of the Ray rule.
So now I do not know how the Rays exactly work. It affects all the models under the template or should I be shooting every model starting with the nearest and when I fail I stop doing so?
Thanks for the answer
PostPosted: Sun Apr 08, 2012 5:30 pm
It is a holdover from the original rules where Rays were treated differently.
Ignore the second sentence.
Hope that helps. :)
PostPosted: Sat Nov 30, 2013 7:20 am
MortalPosts: 1Joined: Sat Nov 30, 2013 7:15 am
They can only make two Movement Actions (Page 28 of the Pulp City Guide) - the restriction only applies to Movement, not two Actions of any type.
You can easily check out our high quality 9L0-412 dumps you well for the Testking You can also get success in real hodges exam with the quality www.quincy.edu and
